6 minutes ago, Lachlan02566 said:
https://au.pcpartpicker.com/list/kpnvy4
This is my list at the moment juts wondering if this is any good wont be looking for a gpu until prices go down just wondering if this is a good place to start
I think this is the one I recommended.
Looks fine (I’m slightly biased)
geometry is hard
b550 > x570
It is hahah I just like to get more opinions no offense to your choice
I believe this is what I'm going to buy just want outside views
1 hour ago, Lachlan02566 said:
how does that work
I could be wrong because 1. I have an Intel system (very little generational upgrade path with that platform) 2. My system is fairly new, and 3. my mobo does not have a BIOS FLASHBACK port on it
Anyways, let me get to the point. For AMD, I think that the motherboards have a FLASHBACK port on them, and I think (I could be wrong) you plug a USB flash drive with the compatible BIOS installed on it, and there is like a light or something on the port and there is a certain color and frequency pattern when it is updating and when it is done, there is another color and frequency pattern. Once it is done, you can boot up the PC and start gaming (after drivers, of course 😀)
PLEASE DONT JUDGE ME IM ONLY SAYING THIS ON VERY LITTLE PRIOR KNOWLEDGE
thank you.
Gaming PC:
CPU- Intel Core i5-10400 (planning to upgrade when Alder Lake releases)
CPU Cooler- be quiet! Dark Rock Slim up to 180W TDP
Motherboard- Asus ROG Strix B460-h Gaming
Memory- Corsair Dominator Platinum DDR4-3000 CL15 memory
Storage- Crucial P2 1TB M.2-NVME SSD up to 2400 MB/s
Video Card- MSI Ventus 2x Geforce RTX 3060 Ti OC
PC Chassis- Cooler Master TD500 MESH ARGB with Controller
Power Supply- EVGA 650w P2 (planning to upgrade to EVGA 80+ Gold 1k watts)
Rear Fan- Touchaqua Bitspower Notos RGB fan
Monitor- Acer EI272UR 2560x1440 144hz 4ms Radeon Freesync monitor
Keyboard- Logitech G810 Orion Spectrum
Mouse- Logitech G203 Lightsync (planning to upgrade to g502 HERO)
Controller- Xbox One Wireless Controller - Red
LaptopProcessor- Ryzen 7 4700U (8c/8t up to 4.1Ghz) with Radeon graphics, 16GB DDR4-3200 memory, 512 NVME SSD
12 hours ago, emosun said:
does bios flashback work without a functional machine of some form to download the bios
I'm sure he can get access to another computer to download a bios file.
This is certainly much better advice than buying an extra CPU.
12 hours ago, Lachlan02566 said:
how does that work
You can find plenty of guides and videos.
Basically you just put the bios file on a USB stick and put it in the port labeled bios then hold down the button for a few seconds. You only need to have the ATX power connector plugged into the Mobo.
And the file usually has to be renamed for each board. I think Asus includes a renaming utility.
16 minutes ago, dilpickle said:
Well gee you don't think he can find another computer to download a bios file but he IS going to have an extra CPU lying around. 🙄
I didnt assume they had an extra cpu on hand which is why I recommended it.  They are more than welcome to accept any advice given there are plenty of options to select. If you recommend a different route they can choose to do that instead no need to discount other recomendations.
