Is Keeping Battery Protect On On my Laptop Worth it?
Solved by it_dont_work,
3 minutes ago, LamoidZombieDog said:i Know a Battery at 100% is the Hardest Strain For it, thats why im thinking this Battery Protection Could Actually Help Long Term. Windows does have a Battery Health Monitor so i can Check that Here and there. The Battery is Likely Made by Samsung as its a Custom Pack.
While that is the case, float charging circuitry is much better these days. I'd probably just leave it on based on your usage.
To play devil's advocate through The offgrid solar on my home runs on 'drop in' lithium deep cycles (agm sized 12v setups with individual bms) and we treat them like absolute shit without any real issues in the last 5 years. the Tech is generally pretty robust
