5 minutes ago, Meczox_YT said:
So I’ve been using my AIO in the front and its higher than the pump and stuff and make air bubbles but i want to flip it but it felt like i was pulling it alot so i didn’t want to destroy the AIO is it normal to pull the AIO To mount it downwards
What do you mean pull it?
Have it so the tubes are at the rear of the case, they are plenty long for that.
2 minutes ago, Meczox_YT said:
Theres no ventilation for that side because mines a cheap case xd
I dont think that you want the piping/tubes below the actual pump itself, and the tubes shouldnt be taut as far as im aware
Edit, besides it looks like the rad is in a good position as it is
Edited by Kevin2334
Oh was i confused than then thank you very much
You didn't watch the video you linked? Link is set to start when they talk about tubes on top..
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
Can you not put it on the top..? On the top as exhaust is your best bet, that way your not blowing all the hot air right into your PC case................. And top is the best for the pump/pump noise.
oh... There is no fan vents in the top? Thats crappy lol
yes and they say at the end while the life of the aio might be affected by the pumps being on top and it is not entirely recommended that it is possible to do so, in this case with no room on top and the tubes pulling then there is no option thus I dont see a need currently to have him/her potentially damage something further, though i do suggest getting a new case that will better fit an aio since this doesnt
and you are correct I miss quoted I meant to say the pump above the pipe, so I do apologize.
if it's putting a lot of tension in the pipes, then dont do that
as long as your radiator outlet is above the pump, you should be ok
-sigh- feeling like I'm being too negative lately
Top of the case, tubes facing down is best. Front of the case, tubes on bottom is next best. Front of the case, tubes on top can be bad. You want to avoid the pump or tubes being the high spot. Air will accumulate there.
Edited by IkeaGnome
Added wrong screen cap.
Project Hot Box
Oppbevaring
  Reveal hidden contents
I agree and thank you for see that I said below I apologize about that
