cheapest 64 bit cpu
Solved by Kilrah,
Look at Socket M Core 2 Duos. https://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#"Merom",_"Merom-2M"_(standard-voltage,_65_nm)
Apparently that machine was offered with C2Ds so it should support some, but I haven't searched long enough to find which, you might have better luck. Ideally get one that it was offered with, as if it wasn't there's no guarantee the BIOS will support it.
