Budget (including currency): 3000$
this is my first pc planning and building any feedback is more than welcome:
 CPU -AMD Ryzen 5 5600X
 Water Cooling -Asus ROG RYUO 240 RGB
Motherboard - Asus ROG STRIX X570-I GAMING AM4
Ram -Corsair Dominator Platinum RGB 4x8GB DDR4 3600MHz CL18
 Storage - Corsair Force MP600 CORE PCIe NVMe M.2 2280 1TB SSD
 Asus ROG-STRIX Modular 1000W GOLD PSU ROG-STRIX-1000G
Case - Corsair Obsidian 500D RGB SE Premium Mid-Tower
Graphics Card -  AMD RX 6900 XT Reference
are those parts any good ? will they even fit into the case and work well together?
thanks for the help.
https://linustechtips.com/topic/1342878-first-pc-planning-build/
Why do you have an ITX board in an ATX case? That's kind of a complete waste of the case, not to mention money. It'll also look really odd.
You didn't state what you're using the computer for. This changes part selection immensely.
I'd try and get CL16 RAM.
16 minutes ago, curiousmind34 said:
1000w is way too much, an rmx750 should be good enough. I would also get a 3080. I would also upgrade the cpu to a 5800x.
Ehhh I mean it's a lot but honestly not overkill for top tier GPUs. Especially if he wants the quietest operation.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Things I'd change:
Motherboard: Gigabyte B550 Aorus Elite | Will accomplish just as much as the Strix board and look much better in your case. -$100
Power Supply: Corsair RM750x | 1000W is like 5950X + 3090 max OC territory. -$175
Case: Corsair 5000D Airflow | Arguably the better case for your money between modularity and aesthetic. -$60
the pc guy
i can get 6900 XT for 1k usd$, getting rtx 3080 for that price is impossible, specialy since i wont be playing anything beyond 1440p.
7 minutes ago, Intravenous said:
also what do you think about this combo:
Intel I9 10850k CPU(can get for 300usd)
and MSI Z590 Gaming Carbon WIFI
Case :Corsair iCUE 5000X RGB Tempered Glass
honestly i dont plan to do much with it, i dont really game much, i got sick for the past year and cant really walk, and i wanna build a pc because  thats something i've never done hoping for "once you build it they will come situation"
If you don't plan on using it much then don't build something that high end. Completely pointless. You'll get the exact same experience with a lower end system.
I want a high end i just dont know if the parts are any good,thats all the help i seek
