Need Help to Reduce Computer Noise
Raptorious
So I bought a prebuilt computer about two months ago (really not a better alternative these days for price) and ever since the first time I turned it on it has just been really loud. For reference I have a Ryzen 7 3700x with a Cooler Master MasterLiquid Pro 120 and an RTX 3070. It seems like the fans are always going basically at full speed and my temps are still just mediocre (45 degree C idle on a Ryzen 7 3700x). My question for the more informed on here is what I would have to do to significantly reduce the noise/ get it as quiet as possible. My first thoughts would be getting a new case/new fans that would provide much better airflow and performance so that the system is not so loud because I just bought the basic case and fans that came with it (regretfully so now). Any help would be very much appreciated as it is really starting to annoy me and having open back headphones does not help.
Have you gone into BIOS to adjust and set fan curves?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
what case do you have?
else you might need other fans if they are noisy, also reducing speed on the fans will for the most part help.
and are you sure they are fans that cant be controlled?
basic fans in pre-builts are often meh or poor, cheaply added but can sometimes do just decently in both flow and noise.
A 120mm rad is worse than a decent single tower air cooler. Temps are about what you'd expect, and if you lower the fan speeds, they will go up. I'd consider a different cooler.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
Try to control fans first. Either with BIOS or using motherboards own tools. Or with 3rd party software.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
