VSCode - Not Using Integrated Terminal
5 hours ago, ATawko said:Thank you for taking the time to assist!
I did not have a launch configuration set for this, so I went ahead and created one. Unfortunately this yielded the same result.
The launch configuration has the specified line included;
{ // Use IntelliSense to learn about possible attributes. // Hover to view descriptions of existing attributes. // For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387 "version": "0.2.0", "configurations": [ { "name": "Python: Current File", "type": "python", "request": "launch", "program": "${file}", "console": "integratedTerminal" } ] }Additionally please see settings.json below from \AppData\Roaming\Code\User\settings.json
{ "workbench.editorAssociations": [ { "viewType": "jupyter.notebook.ipynb", "filenamePattern": "*.ipynb" } ] }
I don't believe any other relevant settings have been modified.
One of the first steps taken was a fresh install of both Python and VS Code.
During the installs of both, the only optional setting used was to add them into PATH.
I looked at my settings.json file, and I see a line that you didn't include in your snippet that could be of use:
"python.languageServer": "Microsoft"
However, I don't know if this will be of use in case you use a different interpreter.
Another idea may be to try using the ">Python: Run Python File in Terminal" command. I don't think it will fix the issue but it could be a temporary way to circumvent it.
