My C: is running low fast, yesterday I had 2GB of storage left, now I only have 500MB - It keeps stacking up with me only launching games. I also have a HDD with plenty of storage to download stuff on, so I don't even use C:
I have no computer knowledge, and no money for new storage.
Is it a problem? And if, how can I fix this?
IF WONDERING WHAT SPECS: i5 2400 - 1650 (low profile design)
https://linustechtips.com/topic/1340827-storage-running-low/
Lets start with Window's own disk cleanup.
Make sure you delete trashbin and update files. Or anything else you dont want anymore.
Selecting the whole list works a charm.
If that doesnt work well enough make sure you have moved you Documents folder to the other drive. You dont want that nonsense on an SSD. (Why Windows doesnt do this themselves boggles my mind).
Right click the my documents folder and click property's. Then in the Location tab change the location to D:\My Documents or whatever you prefer.
If this all doenst free enough room, you might need a 3rd party app to see whats using the most space so you can move/delete.
Like @Electronics Wizardysaid use windirstata or Treesize or similar to see what files/folders take up to much space.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1340827-storage-running-low/#findComment-14754104
