What AIO is best for my build?
Budget (including currency): $1200 USD
Country: USA
Games, programs or workloads that it will be used for: VR Gaming
Other details: https://pcpartpicker.com/list/NdJrgt
Hello I'm new here and building my first PC. I don't know which AIO would be the best option for what I have or if I'd be better off with an air cooler. I haven't picked a case yet because I want a case that will work best with my components instead of making them fit a case.
Country: USA
What case are you going with?
A good air cooler is usually about the same as a 240 AIO. If you get a nice mesh airflow case, air cooling could be a better fit.
I haven't decided on a case yet as I'm looking for a case that will be the best fit for my parts. I don't want to have to try and cram or get different parts because they don't fit in my case.
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($304.98 @ Newegg)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  ($143.00 @ Amazon)
Memory: ADATA XPG GAMMIX D20 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($81.99 @ Amazon)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive  ($114.99 @ Amazon)
Storage: Seagate IronWolf Pro 4 TB 3.5" 7200RPM Internal Hard Drive  ($139.99 @ Adorama)
Case: Phanteks Eclipse P360A ATX Mid Tower Case  ($70.99 @ Newegg)
Power Supply: Corsair CXF 650 W 80+ Bronze Certified Fully Modular ATX Power Supply  ($52.00 @ Newegg)
Total: $907.94
Generated by PCPartPicker 2021-05-21 09:28 EDT-0400
geometry is hard
b550 > x570
IMO for 1200 dollars including a GPU the best option is a prebuilt
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
Don't need an AIO for a 3700X. It's a 65W TDP CPU that doesn't boost past 4.2Ghz.
I'd also like to point out that it doesn't hold any value in 2021, get a 5600X.
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
PCPartPicker Part List: https://pcpartpicker.com/list/3rp7j2
CPU:                   AMD Ryzen 5 5600X   ($304.98 @ Newegg)
CPU Cooler:      ARCTIC Liquid Freezer II 280   ($112.99 @ Amazon)
Motherboard:    MSI MPG B550 GAMING PLUS   ($159.19 @ Amazon)
Memory:            Crucial Ballistix (2 x 8 GB) DDR4-3600 CL16   ($93.99 @ Amazon)
Storage:            Western Digital Blue SN550 1 TB M.2-2280   ($109.99 @ Amazon)
Storage:            Toshiba N300 4 TB 3.5" 7200RPM   ($104.99 @ Amazon)
Case:                 Phanteks Eclipse P360A   ($70.99 @ Newegg)
Power Supply: SeaSonic FOCUS Gold 650 W 80+ Gold   ($84.67 @ Amazon)
Total:                  $1,041.79
[Main Desktop]
[Stream Encoder]
[Garage]
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($299.99 @ Walmart) does better for gaming.
CPU Cooler: Gelid Solutions Phantom CPU Cooler  ($36.99 @ Amazon) no real need for an AIO.
Motherboard: MSI MAG B550 TORPEDO ATX AM4 Motherboard  ($159.99 @ Newegg) don't need the X570-F unless there's something you specifically need from it.
Memory: Team T-FORCE DARK Za 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($149.99 @ Amazon)
Storage: Western Digital SN750 1 TB M.2-2280 NVME Solid State Drive  ($122.99 @ Newegg)
Storage: Toshiba X300 4 TB 3.5" 7200RPM Internal Hard Drive  ($104.99 @ Amazon)
Video Card: Asus GeForce RTX 3060 12 GB DUAL OC Video Card
Power Supply: Super Flower Leadex III Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.00 @ Newegg Sellers)
Total: $973.94
Generated by PCPartPicker 2021-05-21 13:35 EDT-0400
1 minute ago, Herman Mcpootis said:
32GB's of CL18 memory for a Ryzen system focused on VR? 🤔
[Main Desktop]
[Stream Encoder]
[Garage]
An AIO for a 65w CPU seems a bit silly.
Want small formfactor? Or a fancy case?
Or just something cheap and decent like a P360 or similar?
It boosts to 4.6Ghz, and is an easy overclocker. I'd like to see you do it on air without hitting 85+°C
They draw 100W at 4.7Ghz 1.325V
I think it's funny you criticizing my experience with the exact processor when you're still rocking a 1500X. 🤦‍♂️
[Main Desktop]
[Stream Encoder]
[Garage]
Consider using the stock cooler.
17 minutes ago, Herman Mcpootis said:
-snip-
Memory: Crucial Ballistix 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  ($187.99 @ Newegg)
Storage: Mushkin Pilot-E 1 TB M.2-2280 NVME Solid State Drive  ($114.99 @ Amazon)
Power Supply: Thermaltake Toughpower GF1 PE 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($106.90 @ Amazon)
Total: $1011.84
Generated by PCPartPicker 2021-05-21 13:58 EDT-0400
some minor changes id consider. Save some on a similarly performing SSD, pick up a nicer PSU for 7$, and get some Dimms that will overclock well if you want to get into memmory overclocking at some point.
either picking up singlerank Rev B or dual Rank Rev E. Depending on the batch you get.
12 minutes ago, OfficialTechSpace said:
They draw 100W at 4.7Ghz 1.325V.
not sure if you are familiar with the powerdraw of both the 5600x and 3700x. but they both kinda sip power.
and 100w really isnt a lot.
edit: also id consider lowering the voltage you are using. While Zen 2 has been fairly resilient, its not in the range of voltages that are regarded as "safe". If you are using PBO2 to overclock, it may be allright. but allcore overclocks, thats a tad much. Id recommend staying below 1.3v
its an issue of thermal density, something both Zen 2 and Zen 3 deal with.
you are gonna run allright temps, and even be able to overclock using the stock cooler. And a budget aircooler will allow you to make the most of the CPU.
Motherboard: Gigabyte B550 AORUS ELITE ATX AM4 Motherboard  ($149.99 @ Amazon)
Storage: Toshiba N300 4 TB 3.5" 7200RPM Internal Hard Drive  ($104.99 @ Amazon)
Total: $908.94
Generated by PCPartPicker 2021-05-21 14:18 EDT-0400
Generated by PCPartPicker 2021-05-21 14:13 EDT-0400
geometry is hard
b550 > x570
18 minutes ago, GoldenLag said:
Don't need 32GB's for a gaming build.
Is an older version, the N300 drive is newer and the same price.
Costs $150 above entry RTX 3060 cards, for zero benefit.
Not necessary for an RTX 3060 based system.
If you're gonna criticize my recommendations, I'll do it right back.
[Main Desktop]
[Stream Encoder]
[Garage]
If I'm hitting 80°C on a 280mm AIO at 1.325V, where is this thermal headroom you speak of for overclocking? 🤦‍♂️
Not everyone is running test benches, some of us actually have cases. Even with a stock cooler on a test bench you wouldn't be able to sustain much more than 4-4.2Ghz under load.
[Main Desktop]
[Stream Encoder]
[Garage]
it was entirely because it was allready included in Hermans build. also it doesnt list price, so its entirely placeholder. Granted i could have pointed that out.
good to know.
Don't need 32GB's for a VR build.
Might aswell. 16gb isnt exactly sufficient for all titles. And you get to roll the dice on getting Rev B dimms.
which:
  1. Perform well
  2. if you ever want to touch memmory overclocking, they overclock well.
i mean you could spend 7$ less for a Leadex, or spend a little extra for a GF1.
if we are being completely honest, the Focus GM you picked is kinda silly considering what it is. (its listed as a Focus FM, but thats not sold anymore). Especially if you are gonna take the "neccesity" argument.
like you could get something cheap an nice like these:
Corsair CXF 550 W 80+ Bronze Certified Fully Modular ATX Power Supply (CP-9020216-NA) - PCPartPicker
Corsair CXF 650 W 80+ Bronze Certified Fully Modular ATX Power Supply (CP-9020226-NA) - PCPartPicker
i could, but i was really just pointing out the contradiction of saying that an AIO for a 65w CPU isnt neccesary, when you then go on to recommend an AIO for a 65w TDP CPU.......
which I explained here, below:
[Main Desktop]
[Stream Encoder]
[Garage]
Agree with this, the CXFS are really cheap RN (the 650W model is $52!)
I was typing about this as you posted this ahaha
geometry is hard
b550 > x570
Also doesn't OCing Zen 3 hurt single core performance? If OP is playing games why would he OC? Just turn on PBO and call it a day
geometry is hard
b550 > x570
ït does that stock if you werent aware. Well it does more, but assuming some frequency drop for whatever reason.
thats 15c of headroom present. Also ideally you wanna tune through PBO, and not run Allcore overclocks. Also id like to again point out that 1.325v on an allcore overclock (if thats what you are running), is not really ideal in terms of degredation. (tho some chips offcourse handle voltage better than others)
using an AIO doesnt really help the inherent thermal density issue. And you can get the most using a cheap aircooler anyways.
Isn't chip degradation correlated with sustained operating temperature? not voltage? That's what it takes to run stable.
[Main Desktop]
[Stream Encoder]
[Garage]
OC through PBO2 and you can improve performance across the board.
really if you wanna overclock, memmory is what you want to tune.
also, yeah, thermal density. Its why Zen 2 and Zen 3 were "hot" for the amount of wattage they outputted.
also it applies to both Zen 2 and Zen 3. So doesnt really help your contradiction much sadly. Again im just pointing out you are being a bit silly and contradictory with the cooling requirements.
depends on the way it degrades. Temperature is certainly a factor.
You can degrade through too much current (afaik this isnt how N7 typically degrades, could be wrong, i havent looked at specifically the mechanism it degrades by).
but it can also degrade through too much Voltage. Buildzoid touched upon this a bit when he was testing degredation on his degraded 3700x, (which degraded very early on). it finally died through using too high voltage for a couple of days. His sample was apperantly quite sturdy.
