RTX 3060 Power Draw - Should I upgrade my PSU? (400W)
21 minutes ago, Visbi said:I recently saw the LMG 3060 review and I know that I want it, once the price goes down. The problem is that I don't know if My PSU will be enough, and I don't know if I would get the same performance out of a cheaper card because of my low end cpu (Ryzen 3 2200g). Should I upgrade my PSU and/or get a cheaper GPU?Here are my current specs
Cpu:Ryzen 3 2200g
Graphics:2200g apu
Motherboard: Asrock b450m pro4
Memory:8gb ddr4 2666mhz
PSU: 400W evga (not sure which model but I know its the cheapest one they sell)
4 120mm case fans
Cooler: thermaltake a71c
Monitor: acer kg241q
Speakers: htrise 10w
Keyboard: tedgem rgb full keyboard
Mouse: Razer Deathadder Elite v1 and Logitech g203 both plugged in at the same time
Just upgrade to a 550W or more. Don't buy from a sketchy company either.
Edit: Typo
