White Graphics card to fit with my build!
15 hours ago, Clixism said:1. What is BIOS flashing?
BIOS flashing is updating the firmware on your motherboard. If you buy a 5600X CPU and a B550 motherboard, it's possible that your motherboard won't come with a BIOS version that supports your CPU, because B550 launched just before the latest Ryzen series. But don't worry, on the Asus ROG strix B550-A , updating it is very simple. Essentially all you need is to download the new BIOS version onto a USB drive and plug it into the motherboard (without CPU or RAM installed), plug the motherboard into the power supply, and press the BIOS flash button. The board will automatically update itself from the USB drive, and you should be able to boot with the 5600X after. There's detailed instructions on ASUS's website, here.
15 hours ago, Clixism said:And 2. Would a lower end older model Graphics card still work well. Ie. A 1080ti or a 2060?
Yep, it would work fine, and you're probably going to find that older graphics cards are most of what it available in this GPU shortage. A 1080ti or 2060 won't give you the same performance as a 3070 or 3080, but it'll work fine as a temporary solution until things calm down a bit. Just make sure you're not overpaying too hard because prices are all messed up.
