will a higher resolution monitor lower frame rate / reduce performance?
Solved by OfficialTechSpace,
5 minutes ago, TwoAcePilots said:lets say, i have an gtx 1050 ti with a 720p monitor and i upgrade to a 1080p monitor.
Yes, higher resolutions are more demanding, but 1080p should run fine on a 1050 Ti on Medium Settings.
5 minutes ago, TwoAcePilots said:will a second monitor reduce even more performance?
A second monitor would only reduce performance if you're trying to run games in ultrawide using both displays. Merely having two connected at the same time should not affect performance in the slightest.
