DRAM LED Permanently on, System working
Solved by PorkishPig,
16 minutes ago, Tob1d said:I have had the problem with my RAM XMP Profiles not working, so I set the Ram Frequenzy to 3200 Mhz and the system is working without any problems. However the DRAM LED on the Motherboard still is constantly on and i didnt see any warning or something while checking the bios.
Is there anything for me to worry about and how can i fix it?
This just sound like a bug. If you want to fix it, you should try updating your BIOS. BIOS updates are available here, see page 48 of your manual here for instructions.
