so i downloaded hwinfo64 and monitored gpu memory errors and got some errors. tested in doom eternal and csgo and i got errors in both of them. mostly were under 100 but played for around 1 hour. cant notice anything while actually gaming but should i be worried? i dont think its temps problem since i got 2x noctua fans attached to it so it pretty cold. got core overclocked to 1400mhz with undervolt but havnt touched  vram clock or voltage. is it a problem?
https://linustechtips.com/topic/1337620-how-do-i-fix-gpu-memory-errors-on-rx-580/
You need to test it at stock speeds to see if the errors will go away.
If so that just means your OC is unstable, obviously the fix would be to drop the OC a little and try again.
If at stock speeds and voltage, you still have errors then you may have a real problem.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
can core clock affect vram ?
What he is suggesting is that until you check if the problem is at stock - you cant rule out the OC
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Yes it can but it's not the VRAM at fault, it's the GPU core being ran too fast or with not enough voltage in most cases.
You do need to run it at all stock and make sure you don't have a real hardware issue first, just to rule that out.
It could also be a sort of sync issue. I know it XOC, at least on nvidia GPUs, some memory OCs are unstable but one bin higher (15 MHz) and it is fine. But slightly increasing the core clock will make it unstable again until you find a combination that is stable on both. And then you need to tackle LN2 and voltages making XOC so incredibly hard to learn.
Fuck you scalpers, fuck you scammers, fuck all of you jerks that charge way too much to tech-illiterate people.
Unless I say I am speaking from experience or can confirm my expertise, assume it is an educated guess.
Current setup: Ryzen 5 3600, MSI MPG B550, 2x8GB DDR4-3200, RX 5600 XT (+120 core, +320 Mem), 1TB WD SN550, 1TB Team MP33, 2TB Seagate Barracuda Compute, 500GB Samsung 860 Evo, Corsair 4000D Airflow, 650W 80+ Gold. Razer peripherals.
Also have a Alienware Alpha R1: i3-4170T, GTX 860M (≈ a 750 Ti). 2x4GB DDR3L-1600, Crucial MX500
My past and current projects: VR Flight Sim: https://pcpartpicker.com/user/nathanpete/saved/#view=dG38Jx (Done!)
A do it all server for educational use: https://pcpartpicker.com/user/nathanpete/saved/#view=vmmNcf (Cancelled)
Replacement of my friend's PC nicknamed Donkey, going from 2nd gen i5 to Zen+ R5: https://pcpartpicker.com/user/nathanpete/saved/#view=WmsW4D (Done!)
so i ran heaven benchmark everything on stock and still got errors, in games its totally fine, should i maybe try ddu ing the drivers? what  can be cause of errors?
edit:: underclocked vram to 1950 and now i got no errors should i leave it like this can it get worse in future? i really dont wont have to buy gpu right now since even cards like these now cost  around 500$ in my country and i bought this card 1 year ago for 100$
Drivers can be a cause of it.
If the card is getting too hot that's another thing, Heaven can make a card, even at stock get hot enough to throw an error if the cooling it has isn't good enough.
Been there, done that too many times myself.
no temps are really fine around 65-70c i think its fine tho it doesnt has memory temp sensor so i dont know  about that
Don't think - Know.
Sensors can be off and not by a little either, sometimes a sensor will act whacky as all hell and lie to you like no tomorrow.
I've even got a shot in my BIOS of a CPU I once had running in an old Am2 system (Supposedly) at 462c......
Yet there was no smoking crater in the board.
