AIO Liquid Cooling Stops Working
VelikiPCguy
Hey all, I'm building a new PC and thinking of getting a 360mm AIO liquid cooling system for my CPU. While I'm aware that the best air coolers compare fairly well with the best AIO coolers, from I've seen, it seems AIO coolers still inch out ahead by a small margin in terms of performance and quietness. Regardless, I've also heard that some people have had issues with AIOs in the past where the AIO just stops working (and doesn't notify you that it stopped), which causes the CPU to overheat and creates all kinds of problems.
Has this happened to anyone? Is this common, or perhaps just a feature of older / lower quality AIO systems?
Thanks!
3 years with my AIO, nothing has happened yet.
If the pump stops working, the CPU will overheat and thermally throttle.  It won't melt or damage it, or cause "all kinds of problems".
Leaking is the real issue AIO's can face but that's very rare.  It does happen though, so has to be taken into consideration when buying an AIO.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
It is uncommon, not rare, and some of us that have had the issue are lucky enough to still be under warranty. Because it isn't legendarily rare, u need to consider whether or now you want to compromise your build for an inch of performance or save money and reliability with a high quality air cooler.
Fuck you scalpers, fuck you scammers, fuck all of you jerks that charge way too much to tech-illiterate people.
Unless I say I am speaking from experience or can confirm my expertise, assume it is an educated guess.
Current setup: Ryzen 5 3600, MSI MPG B550, 2x8GB DDR4-3200, RX 5600 XT (+120 core, +320 Mem), 1TB WD SN550, 1TB Team MP33, 2TB Seagate Barracuda Compute, 500GB Samsung 860 Evo, Corsair 4000D Airflow, 650W 80+ Gold. Razer peripherals.
Also have a Alienware Alpha R1: i3-4170T, GTX 860M (≈ a 750 Ti). 2x4GB DDR3L-1600, Crucial MX500
My past and current projects: VR Flight Sim: https://pcpartpicker.com/user/nathanpete/saved/#view=dG38Jx (Done!)
A do it all server for educational use: https://pcpartpicker.com/user/nathanpete/saved/#view=vmmNcf (Cancelled)
Replacement of my friend's PC nicknamed Donkey, going from 2nd gen i5 to Zen+ R5: https://pcpartpicker.com/user/nathanpete/saved/#view=WmsW4D (Done!)
For real, even with a factory-sealed AIO? I mean unless you damage it or knock it around, why would it leak?
Oh seriously, so this has happened to you? Did your CPU get damaged or did it just shut off to prevent this?
I hate compromise! 😠
Factory sealed just means... sealed.  Factory or aftermarket... one is not better than the other.
Seals can break.  Rubber, plastic, whatever... can age and crack.  Manufacturing processes can be less than adequate.
I assume the overly dramatic post above ran into an issue and should expand on it for you,  but should also be more realistic about leakage rates (which are indeed rare, if not very rare).  Just because they had an issue, doesn't mean you will.
OnePlus:
Other Tech:
No it hasn't, but I have been around long enough to see it happen a couple times. You CPU won't get damaged by a failing AIO. It could very possibly be damaged by a leak, which is more common than a pump failure. Modern CPUs are very smart now about protecting themselves from damage, especially heat, and without modifying values in your BIOS it will shut down to protect itself 100% of the time.
And you really sound like a kid. U will have to compromise a lot of times in your life, and you will enter stupid fights because of your stubbornness. And it really isn't a compromise. Your CPU would probably not benefit from a AIO, especially as large as a 360mm, any more than a dual 120mm cooling tower would do.
Oh jog on, I was joking
The real problem that no one really acknowledges is permeation. If your AIO doesn’t have a fill port, how do you maintain it? It’s probably not a big deal with some newer CPU’s that sip power and put out no heat.. not to be confused with runs hot.. But older CPU’s that actually put out real heat, or even modern high end Intels lol, by the time you hit the 2-3 year mark you would probably be considering a cooler change. Liquid cooled guys top their loop up every few months, so how an AIO can go for years with no loss in performance is amazing..
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL-B12, 2x TL-K12
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X
Seasonic Vertex GX-1000 | Fractal Torrent Compact, 2x TL-B14
Is this a problem for CPUs like the Ryzen 9 5950X?
It's unlikely to be a problem for most users. A good AIO should last 5+ years without any major issues.
I got 4 years out of my H100, there is not much juice left in it these days.. not enough to handle a stock 7700K. I abused mine with an X5690.
The biggest risk with a AIO is how you mount the Radiator.
due 99% of the AIO's having the pump in the block, if you use a bottom mounted Radiator you risk the pump running dry.
the Be-quiet pure loop is a exeption as it has the pump in the loop itself. not forgetting you are allowed to refill it under warranty.
They even supply a bottle of 100ml of the cooling fluid
║__________________║ hardware_____________________________________________________ ║
║ cpu ______________║ ryzen 9 5900x_________________________________________________ ║
║ GPU______________║ ASUS strix LC RX6800xt______________________________________ _║
║ motherboard_______ ║ asus crosshair formulla VIII______________________________________║
║ memory___________║ CMW32GX4M2Z3600C18 ______________________________________║
║ SSD______________║ Samsung 980 PRO 1TB_________________________________________ ║
║ PSU______________║ Corsair RM850x 850W _______________________ __________________║
║ CPU cooler _______ ║ Be Quiet be quiet! PURE LOOP 360mm ____________________________║
║ Case_____________ ║ Thermaltake Core X71 __________________________________________║
║ HDD_____________ ║ 2TB and 6TB HDD ____________________________________________║
║ Front IO__________   ║ LG blu-ray drive & 3.5" card reader, [trough a 5.25 to 3.5 bay]__________║
║ OS_______________ ║ Windows 10 PRO______________________________________________║
