[HIMB] How is my build?
d6s
Specs:
Case: NZXT Phantom PHAN-001BK Black
Motherboard: GIGABYTE GA-Z77X-UD3H
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz (overclocked to 4.2GHz)
RAM: CORSAIR Vengeance 8GB (2 x 4GB) Low Profile
GPU: GeForce GTX 670 2GB
PSU: XFX Core Edition PRO550W 80+ Bronze
Heatsink/Cooling unit: Custom Water Cooling Loop
post-23399-0-97761300-1396220597_thumb.j
Intel i5-3570K @ 4.1GHz  • XSPC Raystorm • FrozenQ 250mm Liquid Fusion • 8GB DDR3 1600 (PC3 12800) • Gigabyte GA-Z77X-UD3H
Gigabyte GTX 970 G1 Gaming 4GB • Seagate Barracuda 1TB + Intel 730 Series 240GB • ASTRO A40 Audio Solution • D-Link N-150
Those cables though... and you should really switch the in/out on your cpu block
Personally I think it's a bit messy inside and I really question the abilities of a 550w PSU these days. Other than that it seems to be a fairly good 2012 build.
Why would you do a custom loop just to cool your CPU?
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
Because sweg
Messy, tubes and cables everywhere
I have yet to find a tube "route" that suits me...this is just temporary... I had the in / out changed, but it torqued the tube too much because of the small distance from the rad to the block....
