Battlefield V looks grainy and much worse than Battlefield 1 at 1080p Max settings
Solved by Hyrogenes,
7 minutes ago, SpacePilot7132 said:It was at the start, tested it both on and off and both have the problem.
Whenever you get home try running different games to see if the issue persists and run on integrated graphics to see if the issue is with the game or the GPU
1
2
3
ShayOh ·
Posted in Troubleshooting2 -
Newbietobe5467 ·
Posted in Troubleshooting3
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
