Need assistance with case paint job
Nior
I did as advised, sandpaper, primer, colour shifting paint, sandpaper, 2nd coat of shift g paint. After drying the paint turned out heck glossy.
Is there any way to make it matte?
Please advice thanks.
My system : CoolerMaster NR400, Ryzen r7 3700x, Scythe Fuma 2,, Asus TUF b550m plus WiFi (Zaku ii edition), G.skill Trident Z neo 3200mhz 16gb cl16 rgb, Samsung 970 evo plus m.2 1tb ssd, Crucial Mx 500 2tb sata ssd, Asus ROG Strix RTX 2080 super, CoolerMaster MWE Gold 750w.
Cooling : Lian li 120mm uni fans x 7.
Peripherals : Asus TUF series 3 keyboard, Steel series M100, wireless xbox controller, Hyper X cloud 2 headset.
VR : HTC Vive.
Use Matte paint?  Use a Matte gloss?
I recently painted a case, went all matte, its matte af
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
To turn it into matte:
- 1000 grid sand paper or rubbing compound
- or clear matte finish
16 hours ago, LWM723 said:
Get a spray can of matte clear acrylic.
Thanks for the help I'll try the matte gloss first, if the think don't work then the other.
VR : HTC Vive.
