First off all, I'm a noob miner, just started like +/- 3 months ago, i have a asus 2070s and a msi 3080 (if a could get another card at a good price would be great) working at stable 140 mh/s on nbminer. Both cards are on risers and i have my monitor plug in on my 2070s (my R5 1600 don't have a APU), I use the asus tweak to control the 2070s OC and afterburner for the 3080 but now is seams the programs are messing with other because both cards appear on both programs so  some time the oc I want don´t get applied . Also, now when a close the miner the pc freezes or it freezes and i get a BSOD. Don't know what to do.
NBminer
2070s OC: 40 mh/s
Clock: -150
Men: +1100
Power: 70%
temps: 56º
3080 OC: 100mh/s
Clock: -200
Men: +1300
Power: 60%
temps: 39º and men junction 88/90º
https://linustechtips.com/topic/1335849-freeze-and-other-problems/
Are you stable at stock settings? That is power target 100%, clock +0 and mem +0
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
Yes, even with the OC,  while i'm mining i can use the pc with no problems, the crash only happens when i mining and close the miner, I lose input on the display or freeze, sometimes BSOD. Like the Windows dosen't know what to do with the GPU now that they are not mining.
I meant does the same happen on stock settings.
1 hour ago, JP8296 said:
Yeah I understand that, sorry i didn't explain well. Yes same happens with stock settings. This started a few days ago.
Hmm perhaps not an unstable overclock then. Have you tried the usual of reinstalling/updating GPU drivers or DDU-ing them and reinstalling?
Yeah, tried the 'normal stuff', did go back for a early january driver i used before and still the same problem, maeby have to do a clean install
