Casing Fan Suggestion
Go to solution Solved by brownninja97,
I would like to put 2 LED fans on front , and replace the stock cooler from Scout II with 1 more fan,
any good suggestion? I prefer Performance
noctua ultimately is the best, period, other then them which i dont like because they look horrid and honestly you only need to care about performance in a rad. Corsair are decent due to their warrenty, enermax is the company to go for if you want leds however, they beat the performance of corsairs fans and they make the best looking leds. Alternatively if appearance can sway your decision then these fans may suit your needs . Ultimately its up to you also as for a cpu cooler id go for the hyper 212, best bang for buck no question
Hello, I am new to this forum and also into building rig
I just recently purchase a rig as follows :
i5-4670K
Asrock z87 Extreme4
Seasonic s12ii-620W 80Plus Bronze
G.Skill Aegis 2x4 GB 1600Mhz RAM
Gainward GTX 760 Phantom 2GB
WD Blue 1TB
CM Storm Scout II
I have yet to include any casing fan or aftermarket CPU cooler yet, everything is stock cooler.
I would like to have some suggestion on casing fan, i have heard how good is Corsair SP120/AF120 cooling effeciveness.
How much Fans i need to get and how to make intake/exhaust on cooling?
Please help me, thanks.
CPU: Intel i5-4670K CPU Cooler: Swiftech H240-X Motherboard: ASUS Z97 Sabertooth Mark 1 Memory: Corsair Vengeance Pro 1866MHz 16GB Storage:  Samsung 850 evo 250GB ,1TB WD BLUE, Seagate Barracuda 2TB GPU: ASUS STRIX GTX970 4GB Case: Fractal Design Define R5 PSU: Corsair AX760 Full Modular Monitor: Dell 23" S2340L IPS Keyboard: Corsair Strafe RGB Mouse: Logitech G502(w/ Mi Metal Mousepad) Headphone: Audio Technica ATH-M50/MSR-7 Speaker: Edifier Studio 7 R2730DB
https://linustechtips.com/topic/133524-casing-fan-suggestion/
i have 3 of these http://www.enermaxusa.com/fan_uctb14b.php and they are awesome
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1776744
firstly corsair fans are over rated.
next what kind of fans do you like, performance, silent ones, leds or double toned.
You need at least one intake and one exhaust, i prefer to have two of each but its not a must, watercoolers will of course need more.
Listen if you care.
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1776828
After looking at the specs for your case, you can hold at max 8x 120mm fans. I would use these, but there are a number of really good brands to pick from. http://www.corsair.com/en-gb/case-fans/popular-fans/high-airflow-fans?fansize=120mm| or take a look at aerocool and coolmaster.
Connor Freebairn - ConnorFreebairn@newman.cumbria.sch.uk
IT Technician & Certified computer geek.
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1776839
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1776852
at my country i didnt heard much people recommend this, most are Corsair or Noctua.
Any detail review i can refer to ?
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1776855
How about include 2 fans at front , replace the rear fans, and put on a CM Hyper 212x?
Or should I stick to full corsair SP series with H100i ?
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1776861
Listen if you care.
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1776880
What I recommend is get a CM Hyper 212 EVO. Get two Corsair SP120 fans with it. For case cooling, you always want more intake than exhaust. Since yours comes with one exhaust, I recommend getting two AF120 LED fans from Corsair.
FANBOY OF: PowerColor, be quiet!, Transcend, G.Skill, Phanteks
FORMERLY FANBOY OF: A-Data, Corsair, Nvidia
DEVELOPING FANBOY OF: AMD (GPUS), Intel (CPUs), ASRock
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1776884
I'll get a pair of Corsai SP120 Performance , and a Hyper212 Evo then , thanks for the suggestion
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1776974
SP120's are pretty darn loud..Just a heads up.
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1778168
what if i take SP120 quiet edition?
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1780885
The quiet editions are not worth getting compared to other fans. Corsair fans are pretty mediocre for the most part with a few that stand out like the sp120 pe's that perform well, look good, but are really loud.
@Sonifiler's suggestion is pretty much a waste of money. Push/pull does little to help performance and doesn't improve much from the single fan that is already on the 212 Evo. I'd recommend just sticking with the 212 Evo with its stock fan.
Regarding case fans--why replace it add new ones in the first place? Are your temps unsatisfactory?
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1781241
Not one mention of Scythe Gentle Typhoon's?
Case: NZXT H500i. Motherboard: Asus Prime Z390-A. CPU: i7 9700k OC @ 5.0GHz. GPU: EVGA 2080 FTW3 CPU Cooler: NZXT X62. Memory: G. Skill Ripjaws 32Gb 3200mhz. Storage: 1TB Samsung 840 EVO SSD /  120GB Samsung 840 EVO SSD  /  WD Caviar Black 3TB / WD Caviar Green 4TB. . PSU: Corsair AX760. Monitor: 2x Acer XB270HU. Keyboard: Corsair K70 RGB. Mouse: Corsair Glaive.
https://linustechtips.com/topic/133524-casing-fan-suggestion/#findComment-1781298
