PC Restarts Randomly with no Blue Screens or Errors
22 hours ago, DobertRownySr said:Generally, if your computer is just shutting off, that means it's the powersupply. I've encountered this problem twice before, one on my own PC, and once on my friend's. Both times replacing the PSU fixed it.
Worst case, if it doesn't fix the problem, you can just return the new PSU.
21 hours ago, mariushm said:Make a bootable usb stick with memtest and test your ram sticks. test them both together and 1 at a time
if you get errors run the sticks at lower frequency (ex 3000 mhz instead of 3600) or try increasing the latency to something like 18-20 and see if that changes anything.
It's a mini ITX system so it should be fine, slots being so close together but who knows.
The power supply should be fine, the pc shouldn't go over 300 watts or so when gaming.
There were some issues with low power states, disabling some of those lowest c states could be a fix but i have doubts the power supply is the issue.
If possible try as basic configuration as possible, in an effort to try to determine what's causing issues. Ex... disable wifi , put just one stick, maybe try system with some shitty video card you know it's good...
Feel pretty stupid... lol. Did a test with Memtest, no errors. Fans started sounding funny, so I turned everything off and took my PC apart. Turns out there was a random loose screw, I'm not sure what to, might've been an extra I dropped and never realized. Fortunately it didn't cause any hardware failures, so far everything's been fine. If it starts happening again I'll probably replace the PSU. Sorry for the trouble dudes, I didn't hear any fan whirring till after the test. Appreciate y'alls help!
