Continuous beeps and no post screen
Go to solution Solved by Ivancomputerguy,
Ok, so i trouble shooted the thing myself, and i cleaned the ram slots and the ram by blowing into it, and putting it in. Then it got a diffrent beep (1 beep, 3 short) indicating a graphics card erorr. I took out my gpu, did the same to it and the slot, reseated it and it booted flawlessly. I plan to do a lot of things with this pc and i cant wait.
Hello. I just bought this pc for about 2$ to restore it. This machine is very old (15+ years). I blew out the dust with compressed air and it came with no PSU cables, so i connected it with a diffrent one (not sure if this matter, i think its worth noting). I started it up and it startes beeping. I can provide a video if needed. I reseated the ram and i got the same error. Im pretty sure the ram is fine, its just very old (512 mb  ddr1). Power supply is 200-300 watts.
https://linustechtips.com/topic/1334141-continuous-beeps-and-no-post-screen/
From what you are describing it is very likely the motherboard is dead. Did you test it before purchasing or was it for sale as is?
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
