Download DS4windows
http://ds4windows.com/
CPU: Intel Core i9-10900K 3.7 GHz 10-Core Processor
CPU Cooler: ASUS ROG RYUO III 360 ARGB White Edition All-in-one AIO Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z490-E GAMING ATX LGA1200 Motherboard
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3200 Memory Boosted to 4400MHz
Storage: 6 various HDDs and SSDs
Video Card: ASUS ROG Strix 3090
Case: Lian Li O11 Dynamic XL
Power Supply: Asus ROG Thor 1000w
Operating System: Microsoft Windows 11 Pro
Monitor: Samsung Odyssey G9 OLED 49"
Keyboard: Logitech G915
Mouse: Logitech G502 LIGHTSPEED
Headphones: Sennheiser RS 175
Mic: Blue Yeti
https://linustechtips.com/topic/1333547-ps4-controller-help/#findComment-14699138
I tried DS4 windows but can't install it. It needs .net framework 5.0 and when I try to install it it says my OS is not supported. I tried looking this up and turned on the features for .net and it still wont install 5.0. It says my OS is not supported still
https://linustechtips.com/topic/1333547-ps4-controller-help/#findComment-14699178
Well what OS are you running? If you're running windows which version and what build?
Mic: Blue Yeti
https://linustechtips.com/topic/1333547-ps4-controller-help/#findComment-14699361
5 hours ago, fade2black001 said:
Windows 10 x64 pro
Version    10.0.19042 Service Pack 1 Build 19042
Sounds like you have the latest version but it doesn't at the same time. It should look something like the picture shown. if not you may need to update windows.
This may be redundant to what you've done but try restarting your PC then installing this one https://dotnet.microsoft.com/download/dotnet/thank-you/runtime-desktop-5.0.5-windows-x64-installer this link is a direct download from https://dotnet.microsoft.com/download/dotnet/5.0
Also just tested it and apparently I didn't even have it installed. Which is weird because DS4Windows has always worked for me. Also try installing the version of DS4windows from the link I gave you https://github.com/Jays2Kings/DS4Windows/releases It's an older version from way back in 2016. .NET 5.0 wasn't even a thing yet and should work just fine. I'm going to try the new version from the link the other guy gave and see if I run into any issues.
Mic: Blue Yeti
https://linustechtips.com/topic/1333547-ps4-controller-help/#findComment-14700040
So the other version works pretty well also. So if on the off chance the links i've provided don't work you could also look into just straight up installing visual studios.
Mic: Blue Yeti
https://linustechtips.com/topic/1333547-ps4-controller-help/#findComment-14700105
 Well I guess something happened somewhere and now my controller isn't even recognized by Windows anymore. The light goes to an orange color and not blue and turns off. I tried the old versing of DS4 you provided and installed the driver and nothing works with it either.
Edit 1: OK I was able to to get the controller to turn on now but still not showing up in DS4Windows.
Edit 2: I got everything working now. Hopefully it stays this way and not run into anymore problems
Thanks for the help
https://linustechtips.com/topic/1333547-ps4-controller-help/#findComment-14700245
Thanks for the help
No problem, just come back here if you need further assistance.
Mic: Blue Yeti
https://linustechtips.com/topic/1333547-ps4-controller-help/#findComment-14700532
