Budget (including currency): 1000
Country: USA
Games, programs or workloads that it will be used for: Minecraft, Rainbow Six Siege, and CSGO
https://www.ibuypower.com/Store/Gaming-RDY-TMRIIRG208
Is this a good deal?
https://linustechtips.com/topic/1333425-first-pc/
Country: USA
Only 500MB of storage, just one 8GB stick of ram, a GTX 1660 super with crappy cooler, and a case with poor front panel intake airflow... Meh, you could do worse, but pricing out the parts at normal-ish prices would bring you kinda close to this.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1333425-first-pc/#findComment-14698443
Country: USA
A520 motherboard , just don't use it better get a b450 motherboard as it gives futher compatibility options with other ryzen CPUs  and if you are not going to get more ram in future it's okay to go with single 8gb ram and case is not good .
https://linustechtips.com/topic/1333425-first-pc/#findComment-14698525
