2 minutes ago, Fraizz said:
I7 7700
rx580
16gb ram
prime z270 a
256gb ssd
1tb hdd
What's the make, model, and wattage of the power supply?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1333013-help-boot-issues/#findComment-14695363
2 minutes ago, Radium_Angel said:
Is the system sitting idle when it reboots, or is it under load?
What changed between when it worked, and when it broke?
nothing i booted up, went to check the temperatures and it rebooted. mind you this happened in the span of 2 3 minutes
https://linustechtips.com/topic/1333013-help-boot-issues/#findComment-14695375
Look in the Event Viewer and see if there is anything in the System Subsection that might point to what happened
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1333013-help-boot-issues/#findComment-14695384
1 minute ago, Fraizz said:
let me try, but i wont burn my components while trying to do this right? the first reboot has had me shook already
No, no further damage will happen. If anything Safe Mode is more gentle on hardware than normal mode, but it will give us an insight potentially as to what's going on
https://linustechtips.com/topic/1333013-help-boot-issues/#findComment-14695400
ok if you could guide me from booting into safe mode that would be great
https://linustechtips.com/topic/1333013-help-boot-issues/#findComment-14695406
Straight from Microsoft
https://support.microsoft.com/en-us/windows/start-your-pc-in-safe-mode-in-windows-10-92c27cff-db89-8644-1ce4-b3e5e56fe234
(you'll want the 3rd option, "from a black or blank screen")
https://linustechtips.com/topic/1333013-help-boot-issues/#findComment-14695411
