Sweaty hands vs Legendary final mouse
Solved by HeyCya,
It's fine to have 'sweat hands' with one of these mice. The only thing you'll have to look out for is cleaning it (taking the cover off and wiping it down, or something of that sort) more frequently, but the electronics inside won't be affected.
Longevity of the mouse might be a factor, but in my opinion you should be fine as long as you clean it at least once every 2 years or so.
