I have a fairly used gaming pc that none of the components have changed in for 3 months at least.
Ryzen 5 3600x
asus rog b450f
32gb 3200mhz teamgroup ram (4x8)
evga 1080ti
samsung 970 m.2 ssd
inland 2.5” sata ssd
today randomly after no changes in my system for months I was listening to Spotify and playing league of legends with friends on discord and I got a random bsod(pic attached). I rebooted the system and everything was fine for about 3 hours then it happened again, same stop code.
I googled this code and it said something like windows has shut down to prevent data loss.
talked to a couple friends and they suggested bad ram. I ram windows memory diagnostic tool and it says hardware problems detected. This ram is about 6 months old.
any suggestions on narrowing down what stick is having a problem so I can use my computer?
"If you gon be bout it, be bout it bout it" ~ Gavin 'itsjusta6' Simon
I play games - Look at my profile for specs
I love memes. I make bad memes, but I like dank memes, who doesn't?
I am good at editing videos and pictures, feel free to message me if you would like some work done.
Thanks!
Kole Overby
Owner At:
Chaos Network
DanTheNali Videography
Employee At:
Neighborhood Mechanic
Heinen's Powersports
https://linustechtips.com/topic/1332187-how-do-i-narrow-down-my-problem/
1 minute ago, fuzz0r said:
Run memtest86 to make sure it is the ram.
If your RAM is only 6 months old, get them RMA'd.
currently have the pc up and running in windows, is there anything i can do from within windows? honestly was planning to upgrade to a 2x32 gb kit in the next month or so, so i just want to figure out which stick(s) are bad so i can use it reliable until then
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
I don't know of any way to test which memory stick is bad from within windows.
I think you'll need to boot into memtest to find out.
Be sure to take pictures of any error codes.
i have no idea how or why, but it has now been stable going on 16 hours according to uptime in task mgr
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
