3 minutes ago, cloneclone said:
where plug usb plug into?
i have nothing to plug this usb into
its wireless headphone
dont come with charger, only usb plug
what plug usb into
have nothing
If you cant speak english fluently, consider just using google translate in your native language.
Anyway, the USB port (micro-b or type-c) on the headphone should be able to charge the headphone with any adapter, while also putting the headphone in "wired mode". But a pictures would be appreciated to help on this.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1331122-how-charge-usb/#findComment-14681178
Just now, cloneclone said:
dont have any
it didnt come wit 1
Then you'll need to buy one.
how we charge usb ??
Plug it into any USB charger or a USB port on your PC. If you have neither of those, then you'll need to buy one.
https://linustechtips.com/topic/1331122-how-charge-usb/#findComment-14681203
