Ramtest 64 help
Go to solution Solved by Radium_Angel,
Just now, POG Gamer said:
There brand new and overclocked do I need to give more Voltage
Turn off OC, test again, you need to work from a baseline to ensure they are, in fact, good, before you go mucking about with OCing
Just now, Radium_Angel said:
Bad RAM, time to replace them
KanyeWestLover911
Reminder
I'm just speaking from experience so what I say may not work 100%
I Use Arch BTW
my PCs
these are my Pcs
https://pcpartpicker.com/user/mtj08/saved/
https://linustechtips.com/topic/1330260-ramtest-64-help/#findComment-14674694
1 minute ago, WereCat said:
That your RAM is not stable.
You need 0 errors or you risk data corruption and a lot of system crashes.
Ok more voltage?
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
https://linustechtips.com/topic/1330260-ramtest-64-help/#findComment-14674695
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1330260-ramtest-64-help/#findComment-14674699
Ok
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
https://linustechtips.com/topic/1330260-ramtest-64-help/#findComment-14674702
1 hour ago, WereCat said:
Sometimes it can help. Not a guarantee. May try to up a memory controller voltage as well if youre using high memory speeds.
So far I have gotten up to 3800Hz with no errors
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
https://linustechtips.com/topic/1330260-ramtest-64-help/#findComment-14674907
