Plugged my power cable to a 110v and another for 220v, it runned but when i open a 4k wallpaper started to turning off then avr it smoked
The computer's power supply is probably designed to accept a wide input voltage, something like 90v ... 250v AC. So it would not care if it receives 110v AC or 230v AC, it will take in anything and produce the right voltages for the components.聽
聽
BUT, check the labels of your power supply and see if it's wide input voltage. It's written on the power supply label.聽 If it's 230v only (or 220v+), then your power supply should have shut down with just 110v.聽
聽
聽
The AVR is an auto voltage regulator ... my guess is that regulator has a simple transformer with multiple secondary taps and it just switches between taps to keep the output voltage within some range.聽
聽
If the AVR uses a transformer and that transformer was made for 220..250v but you powered it with 110v, the that transformer probably got overheated and probably got damaged.聽 If you got smoke, I would not use that AVR anymore, because probably the insulation on wires inside that regulator is burned so it no longer safe to use.聽
聽
聽
