Hackintosh build - need second opinion
Go to solution Solved by BondiBlue,
You will need a dGPU. Your integrated graphics are not supported by macOS.
Budget (including currency): 0
Country: EU
Games, programs or workloads that it will be used for: apple stuff
Other details:
Hi, I have some left over Hardware from my last build:
ASRock H110M-ITX
8gb DDR4 2133Mhz
Intel Pentium G4650
250w psu
and a 2he short depth Rackable case
Since I havent really done anything Hackintosh stuff to this date I was wondering whether this build would still offer somewhat performance.
The Tasks I do on Mac are usally stuff like backend solutions with docker / kubernetes etc. ( I normally use a Macbook 15" 2018 for that)
Maybe someone can give me a little info, which version of macos i can use, whether I should keep the current config or maybe upgrade the cpu and such.
Thank you in advance
https://linustechtips.com/topic/1329384-hackintosh-build-need-second-opinion/
Phobos: AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 8GB Nvidia GeForce RTX 2070, 2GB Nvidia GeForce GT 1030, 1TB Samsung SSD 980, 450W Corsair CXM, Corsair Carbide 175R, Windows 10 Pro
Polaris: Intel Xeon E5-2697 v2, 32GB 1600MHz DDR3, ASRock X79 Extreme6, 12GB Nvidia GeForce RTX 3080, 6GB Nvidia GeForce GTX 1660 Ti, 1TB Crucial MX500, 750W Corsair RM750, Antec SX635, Windows 10 Pro
Pluto: Intel Core i7-2600, 32GB 1600MHz DDR3, ASUS P8Z68-V, 4GB XFX AMD Radeon RX 570, 8GB ASUS AMD Radeon RX 570, 1TB Samsung 860 EVO, 3TB Seagate BarraCuda, 750W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
York (NAS): Intel Core i5-2400, 16GB 1600MHz DDR3, HP Compaq OEM, 240GB Kingston V300 (boot), 3x2TB Seagate BarraCuda, 320W HP PSU, HP Compaq 6200 Pro, TrueNAS CORE (12.0)
