Broke a component on my motherboard, possible to repair?
Hi, I broke a component of my motherboard (aorus b550i pro rx) when closing the top lid of my pc, the top fans + cable were too much and I didn't look properly before applying force.
It didn't fell off completely but it looks like it took a small part of the pcb with it.
The pc doesn't boot, all the fans rotate but I get no display.
Do you think it can be repaired or should I just buy a new one? The motherboard is brand new, like one month old
Thanks!
It looks like the pads lifted, i.e. the metal parts of the PCB are no longer bonded to the substrate, so the circuits are broken and it's essentially impossible to repair.
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | a 10G NIC (pending) | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X540-T2 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ────────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Switch Flex XG ═╦═ Veda (Proxmox Virtual Switch)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)           ╠═ Veda-NAS (HW Passthrough NIC)
╔═══════════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2.5G NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ──────────────────────────────────────────────────────┐
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═╦═ Byarlant
   (PoE)                 │                        ╠═ Narrative (Cable Matters USB-PD 2.5G Ethernet Dongle)
                         │                        ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
Yes, it's possible to repair.
Go to a service place that repairs computers or phones and have soldering stations.
The component pulled the copper pads to which it was soldered, so the person working on the motherboard would have to look to what traces (copper wires on the board) the component pads were connected to, scrape off the layer of insulation from those wires and solder new wires between those traces and your component.
Another technique is to desolder the pads from the component, glue them back to the circuit board, create a bridge between the pads and the copper traces to which the original pads were attached, and then solder the component back onto the pads.
The component is an inductor , basically a coil of wire wrapped around a ferrite core or some other core with magnetic properties... then all is wrapped in the plastic cube to reduce noise produced by the wire rubbing against the core material.
It's part of a dc-dc converter, a circuit which takes some higher voltage and produces a lower voltage  ...  based on the location it may be powering the memory sticks.
Looks like you ripped the copper pads off so that mobo is done.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
This is BAD ADVICE.
Lifted pads or broken pads can be repaired, or an experienced service person can use wires instead of pads to create the connections.
here's an example from a company NorthridgeFix that have a Youtube channel and you can send them your motherboard to have it repaired, but it would probably be expensive:
This is a usb stick which had the pads lifted ... he's using wires to create the connections and get the stick working :
See at around 2:30 for example ... same thing can be done on your motherboard :
another example, a hdmi connector with lifted pads and broken traces ... it can be repaired :
Alright, thanks for the awesome feedback, repairing it looks like too much trouble, I'll just buy a new one and sell this one for parts
I'll be more careful next time, thanks again !
Cheers,
4 minutes ago, mariushm said:
This is BAD ADVICE.
Both of those are low current, low voltage applications. I don't doubt it can be done for applications like that, but the (relative) amount of current flowing through that inductor would be enough to smoke those fine wires being used for those fixes. It might be possible, but it's pretty iffy to find enough space to solder a large enough wire to hand the current.
Network:
                         │                        ╚═ Jesta Cannon*
Retired/Other:
It's a "one phase" dc-dc converter, it's not a high current, maybe a few amps at most ... and it's two lifted pads ... you can solder multiple thin parallel wires if you're paranoid. Even with just thin wires, a thin wire can handle a lot of current if the distance is very short ... like half a cm or whatever you'd have in this situation.
Shame I live where I live, I would have been willing to give it a shot, maybe buy the board as is and try my luck, but shipping to me would be very expensive. Don't have near as high end soldering equipment as the ones in the video, but I think I'd manage to fix it.
Just now, mariushm said:
This is BAD ADVICE.
It's perfectly sound advice that I gave. The OP is asking whether or not it is worth repairing, not if it is repairable. It's a ~$200 motherboard so no it is definitely not worth paying the labor costs involved with fixing a $200 item.
