Replacement GPU fan sources, (5700XT MSI Evoke OC)
tl;dr Anyone found a good place to get the correct size fans for specific graphic cards?
Ive got a AMD 5700XT MSI Evoke OC, one of the fans has started intermittently buzzing at high speeds.
now I'd rather not send a GPU out for repair as there'd be no way to use this PC in the meantime,
I did reach out to MSI's support who said they couldn't sell the fans on their own, but could sell the entire cooling for the GPU (heat-sink, shroud, fans)
But they gave a approx cost of £110 +tax and shipping, (not bad if you needed the entire cooler, but annoying as i only need the fans).
So i'm trying to hunt around for a matching compatible fan, or dip into water-cooling as a block from Alphacool is €98 (plus the rest of the water-cooling loop)
What's your recommendations?
eBay. Old Sapphire HD 7XXX cards used to have fans fail on me all the damn time. eBay had OEM fans on the cheap for those Sapphire cards like you would not believe, and they probably still do.
Aerocool DS are the best fans you've never tried.
cheap fans from ebay or Arctic Accelero Xtreme aftermarket coolers
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
