2 minutes ago, Mf_pancakes said:
I just got a 3090 and im using it in my coolermast q500l and it is very small so it has terrible cooling could someone recommend a better and bigger one for looks and performance in cooling?
Corsair 4000D Airflow
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1328657-best-case-for-cooling/#findComment-14661919
12 minutes ago, Mf_pancakes said:
I would suggest looking up gamers nexus reviews particularly his case awards for all the arears of which certain cases do best. lian li does very well but really all the mesh do the best overall like the phanteks p500a digital if probably the best big case for airflow.
https://linustechtips.com/topic/1328657-best-case-for-cooling/#findComment-14661940
I vote for Meshify C
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1328657-best-case-for-cooling/#findComment-14662084
  • 2 weeks later...
I've got an inverted build in a Q500L (although admittedly with a much lesser GPU)  and I have no problems with temps
Its also got a total of 8 fans running, 4 intake and 4 in push/pull exhaust on the radiator which probably helps although I haven't (as some people have) resorted to dremellling parts of the case open.
https://linustechtips.com/topic/1328657-best-case-for-cooling/#findComment-14688186
All good cases with mesh panels for good airflow in a few different prices ranges.
Lian Li Lancool II Mesh
be quiet! Pure Base 500DX
be quiet! Silent Base 802
Phanteks P500A Digital
Fractal Meshify 2 / Fractal Meshify 2 Compact
CPU: i9 9900K   Cooler: NH-D15   RAM: Kingston Fury 4 x 8GB 3600MHz CL17   Mobo: ASUS ROG Strix Z390-F   GPU: ASUS 3080 TUF   Case: Be Quiet! 500DX   PSU: Corsair HX850i   Storage: 250GB Samsung 970 EVO NVMe (OS), 500GB Samsung 970 EVO NVMe (Games), 2TB Crucial BX500 SSD (Storage)   Monitor: Samsung Odyssey Neo G9.
https://linustechtips.com/topic/1328657-best-case-for-cooling/#findComment-14688364
