Hello, I am looking to get into photography and I would like to know what camera i should get for under £300 as a beginner. I only need 1080p and clean hdmi out would be nice (no power on time limit too) as I plan to also use this to stream. Thanks in advance. (Used is fine, been looking at amazon renewed)
https://linustechtips.com/topic/1328541-first-mirrorless/
The best camera for you, is the one you will use, because it fits into your hands nicely, and is logically laid out for you.
I used a Nikon D2x for outdoor concert events.
Lugging that metal around for a weekend (plus a 7-200mm f/2.8 all-metal lens) was murder.
So I switched to a mirrorless rig.
Light as a feather.
And completely impractical because it was too small. Ended up giving it away after one event and going back to my Nikon.
So nevermind the reviews, go out and hold one, see if it fits.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661239
Light as a feather.
Ok, thanks, will continue looking into amazon renewed as that seems promising for my purposes. Will make sure to use the return to try more cameras.
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661252
Dunno where you are, but there should be some camera clubs or shops where you can get a hands-on feel for them.
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661262
Only place I could think of is currys that is near but because of Covid your not aloud to touch display pieces. Any cameras I should avoid? Or should I just get one that is decent(eyeing up a fujifilm x-t10)
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661292
so you are just after a nicer webcam? which case why go DSLR/mirroless
or are you trying to get 1 camera to do both
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661372
As I stated I am also wanting to get I to photography but as I said that is a plus and not a must. Only must is that it is under £300, been looking for renewed as new is too expensive;-;. Again I am only asking as I am not very well versed in what cameras are good and I am only just beginning.
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661380
okay well then your looking at used body+lenses. you aren't going to get anything new for 300£.
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661392
1 minute ago, Janettebot said:
It doesn't have to be anything new, just something to begin with. I can however get a body and lens separate for £500 total.
so wait is your total budget for the 2 500£
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661400
https://www.amazon.com/Olympus-Mirrorless-Touchscreen-Discontinued-Manufacturer/dp/B0074WDERI
These cameras are *small*, way too small for my hands, even with the battery grip, but they are highly capable.
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661442
1 hour ago, Radium_Angel said:
I'd likey go PanasonicG80 with 12-60mm
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661577
27 minutes ago, Janettebot said:
Il look into the Panasonic, what about this Olympus instead of radiums suggestion?
its old from 2012, it uses a much older sensor, believed to be a GH3 sensor
G-80 is a 2016 body based on a 2015 sensor
MFT senors changed a lot in those years
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661687
Ok thanks, will try to find an mft lens for the Panasonic because I can only find it body only.
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661692
Couldn't find a g80 and lens within my price range however I did find a sony a6000 under £500 with lens https://www.amazon.co.uk/gp/aw/d/B00IE9XHE0/ref=psdcmw_430660031_t1_B013QWFKZ8?th=1&psc=1
I doubt the lens will be that good but until I can get a separate lens il put up with it. Is it a good deal?
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661723
Made a mistake, will add a new suggestion.
Edit: Suppose the Canon EOS m200 ticks the boxes while being only a bit above budget (if you can find a kit with lens). It has clean HDMI output for streaming, and has a fairly large sensor for photography.
My eyes see the past…
My camera lens sees the present…
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661753
I was on CVP and assuming a 500£ budget
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14661764
I found both the m200 and an eos 2000d for similar prices. Thoughts? Just making sure I dont get a bad camera.
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14662243
the Canon's you're looking at aren't bad camera's and really you're the only true judge of that.  Personally I prefer Canon's UI and functions over other company's out in the market.  I'm still running a Canon XSi (450D) and a  50D w/ a MagicLantern video mod.  I have had the pleasure of using the older M series and loved it for a small run and gun when needed.  I would almost as friend's and family if they have camera's you could try out and play with for a day (hoping for a variety of models) so you can find something that you like in the hand and UI.  It's very hard to recommend a camera since we're not you and don't know (from your perspective) how far you're wanting to dive into photography/etc.  Thanks to advancements in tech there is no such thing as a completely bad camera for those who want to get started (within the main company's in the market).
Funny thing is even w/ my DSLR's I always end up just using the camera I carry around in my pocket the most as it's easier to get out and ready, which is my phone.
Project Gray Scale
Intel Core i7 6900k @ 4.2Ghz - Dominator 32GB DDR4 2400 CL10 - Samsung 970 EVO+ 1TB NVMe - 2 Samsung 840 EVO 1TB (Gaming and Sratch) - 2 Barracuda 2TB
Asus x99 Deluxe - MSI Aero OC GTX 1080Ti - Seasonic 760 XP² - Mod1PC Custom Cables - EKWB CPU & GPU Blocks Nickle/Plexi - EKWB D5 PWM
EKWB PE360 - Corsair ML120 (6)  - InWin 303- NK65 Entry Watermelon w/ Gat Laseron 70g (205g0 & Filmed) - Logitech G Pro x Superlight
Kanto YU2 - Sennheiser PC360 SE - Acer XF270HU
BUT DOES IT FOLD?! https://folding.extremeoverclocking.com/user_summary.php?s=&u=963814
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14663556
Ah, that's my problem. My phone is a budget phone from 2017 so the camera is not great. Even post processing doesn't help. However I have used a friends phone before (I think it was an s9) and it was alot better. And that's where i started to want to do photography, I am only a beginner so used and older cameras are fine. I've been looking at canon d5 mk ii cameras and an ef lens and that brings me to about £400 for the whole setup, is it a good deal? I like the idea of having a full frame camera.
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14663652
A 5D mk II is a solid camera, especially since they can be found for good prices thanks to the newer versions out now.
Project Gray Scale
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14664021
Yeah, think il go for the 5d mk ii because it's better for the price than new cameras at a similar price. Thanks : )
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14664140
Also you'll get a Full Frame sensor to play with 👍
Project Gray Scale
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14664159
5dmk2 is a decent photo only body.
https://linustechtips.com/topic/1328541-first-mirrorless/#findComment-14664318
