USB C - Ethernet?
Solved by WereCatf,
51 minutes ago, krillindiesagain said:Im sorry to ask you again about this. My biggest confusion was that i thought you need a thunderbolt port for it. Just want to confirm that it works with AMD too! Sorry and thanks!
Nope, you don't need Thunderbolt for a basic gigabit USB-Ethernet-adapter and yes, they're just basic USB-devices, so they'll work just fine on AMD as well.
