First off, the specs.
Asus RTX 3060
Ryzen 5 5600x
Samsung 970 Evo SSD 1TB
Unknown John Doe Hard-drive 2TB
2×8 Corsair Vengeance Pro ddr4
On a Rog Strix B550-F Gaming board
Right, so I can start up the computer fine and watch YouTube, Hulu or Hbo max fine. I can only play siege (R6) in training mode. The board will crash if I launch Apex Legends. A little red light abruptly comes on and the restart process begins. We originally thought it was because my old pre-built had an illegitimate version of windows that he stole from our school. But I've bought my own product key now, implemented that annnnnd it still crashes...i honestly dont what to do and i miss streaming with the bois, can anyone please help?
https://linustechtips.com/topic/1327693-help-random-reboots/
excuse me WHAT?
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1327693-help-random-reboots/#findComment-14655241
Asus RTX 3060
Ryzen 5 5600x
rather than focusing on the Windows Key 😄 try to troubleshoot the hardware. for starters, check your powersupply
https://linustechtips.com/topic/1327693-help-random-reboots/#findComment-14655247
1 minute ago, SignatureSigner said:
excuse me WHAT?
He pirated our old high-schools windows office for his pre-built (my old system) i thought i could use the windows from my old system so i put in my old hard drive, and found out that the windows wasn't legit, ive since then bought my own product key but i still cant get my games playing properly
https://linustechtips.com/topic/1327693-help-random-reboots/#findComment-14655254
Get-WinEvent -FilterHashtable @{logname = 'System'; id = 1074, 6005, 6006, 6008}  |
                     ForEach-Object {
                         $EventData = New-Object PSObject | Select-Object Date, EventID, User, Action, Reason, ReasonCode, Comment, Computer, Message, Process
                         $EventData.Date = $_.TimeCreated
                         $EventData.User = $_.Properties[6].Value
                         $EventData.Process = $_.Properties[0].Value
                         $EventData.Action = $_.Properties[4].Value
                         $EventData.Reason = $_.Properties[2].Value
                         $EventData.ReasonCode = $_.Properties[3].Value
                         $EventData.Comment = $_.Properties[5].Value
                         $EventData.Computer = $Computer
                         $EventData.EventID = $_.id
                         $EventData.Message = $_.Message
                         $EventData | Select-Object Date, Computer, EventID, Action, User, Reason, Message
run the command above inyour powershell, it will tell you why your pc has rebooted
https://linustechtips.com/topic/1327693-help-random-reboots/#findComment-14655280
