Help, please.
Solved by Matszhie,
On 4/16/2021 at 6:47 PM, Teixeira79_ said:
A cpu score of 4.2k shouldn’t bottleneck a 1050 Ti. Usually a i5 8400 scores around 5000 here, but that is without any background applications open, so yours is probably fine. I therefore do not think that it is your cpu, so then the aforementioned solutions about having dual channel would help you.
