Budget (including currency):
$3,000
Country:
Unites States
Games, programs or workloads that it will be used for :
streaming/gaming
Okay so I was able to get my hands on a 3070 FE and also a Ryzen 9 5950x and my question is if that's even possible to run without bottlenecking? I have attach and image of what I was wanting to do please let me know what I can improve or what is best for my asking which is stream and game. I'm all ears and open to all opinions after all you guy are the ones that know about this I know very limited things
https://linustechtips.com/topic/1327542-help-with-my-pc-build/
$3,000
Country:
Unites States
streaming/gaming
You may want to go with 3600 CL16 due to how high end this build is but otherwise it looks fine
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1327542-help-with-my-pc-build/#findComment-14654042
Ok, this isn't bad. I think you should get an MSI GPU, and with this budget you can upgrade to a 3080. The ram was a splurge, you should go for 4X16GB 3600MHZ Trident Z Neo, RGB, or Corsair Vengeance. Dominator is kinda a splurge. You should also get a 850W power supply.
https://linustechtips.com/topic/1327542-help-with-my-pc-build/#findComment-14654051
Okay nice and man that would be the dream to get my hands on a 3080. Also I like the Dominator but I guess your right lol and I can upgrade the power supply and Ram. Thanks for the feed back.
https://linustechtips.com/topic/1327542-help-with-my-pc-build/#findComment-14654063
