help with psu cables for gpu
Go to solution Solved by Spotty,
6+2 pin PCIe are the same as 8 pin PCIe. Some graphics cards only have 6 pin connectors so the 6+2 is so it's compatible with both the 6 pin and 8 pin connectors.
