Budget (including currency): $1300
Country: USA
Games, programs or workloads that it will be used for: Gaming, small video edits, music production
I'm upgrading from my prebuilt lenovo y710 that's running an i7-6700, gtx 1070, 16gb single DIMM ram at 2133mhz, 256gb ssd and 2tb hard drive. I mostly use it for music production, but when I do game it's either Halo MCC or Overwatch and I'm usually able to get between 110 to 120fps in OW, max 60 in MCC. I've already ordered parts and feel like I did a decent job picking parts but am having a few doubts about my choices. I've got everything but my MB, case, and both storage drives in, but they're all shipped. Want to make sure that I didn't make a screwy decision in my parts since it's my first build. I'm including a 1070 in the list because I plan on swapping it in from my current computer to the new one. Any tips or recommendations or things I may have missed in terms of compatibility?
https://linustechtips.com/topic/1327484-first-build/
i don't know why you're asking when you already bought everything, since there's not much we can change after that anyway.
https://linustechtips.com/topic/1327484-first-build/#findComment-14653607
1 hour ago, curiousmind34 said:
MB, go for Z490. A Z490-a pro should work. For storage, I would replace the larger drive witth an sn550
See I thought about that but I was told that western digital nvme ssds weren't as reliable as the samsung drive. And I had a really slim budget to build with otherwise I would have gone with a z490 board. Specially after learning that the board I chose can't do overclocking and it has a really low memory limit. Thought I did enough research but a lot of the deeper intricacies popped up after I ordered everything. My first time ever even attempting something like this so when I saw that I got real worried that everything else might be screwed.
https://linustechtips.com/topic/1327484-first-build/#findComment-14653841
I just wanted to make sure man. It's my first build, or even first time trying something like this so I thought I'd go and get opinions on things even though it's after-the-fact.
https://linustechtips.com/topic/1327484-first-build/#findComment-14653849
Both of the drives have the same warranty of 5 years and 1200 Terabytes written. If you didn’t want to overclock or be on a z series board you could have gotten an i9 10900 and saved a few bucks.
https://linustechtips.com/topic/1327484-first-build/#findComment-14654709
