Do you have any suggestions for improvement of my pc setup:
I have an ryzen 5 3600 with and asus rog strix b450-f mainboard and an gtx 1660 super.
For storage I have an 1tb m.2 ssd and an normal 1tb ssd.
For RAM i have and 16gb (2x8gb) kit.
My power-suply is an 700watt be quiet.
https://linustechtips.com/topic/1327273-can-u-help-me/
honestly that's a good build.
if you wanna improve it its just going to cost quite a lot for not  a huge amount
CPU AMD 5800x_____Asus Crosshair VIII_____Asus Strix LC 360_____RAM Corsair Dominator Pro 2x8Gb 3600mhz_____ASUS RTX 3080 Strix
PSU Corsair HX1000w_____CASE Lian Li 011 Dynamic (original choice right? w/9 UNI Fans)_____Keyboard Razer BlackWidow Chroma_____Mouse Razer Deathadder Chroma_____Headphones Bose QC25_____Monitor (1) Acer Predator XB1 144hz G-Sync  (2) Benq 144hz G-Sync
Microphone Blue Yeti Black
Razer Blade 14
Also an XBOX one s.
https://linustechtips.com/topic/1327273-can-u-help-me/#findComment-14651994
2 minutes ago, boggy77 said:
what exactly do you want to improve? what do you do with your pc? what is limiting you currently? what is your budget for said improvement?
Just if there is an Motherboard in the 100-150 dollar price class with an better chipset mybe or and better pcie slot.
or an better cpu in the 200 price class. I am using the pc for gaming and video editing.
https://linustechtips.com/topic/1327273-can-u-help-me/#findComment-14652040
that is not going to affect your performance in any way
no better cpu for 200.
for gaming, a gpu upgrade would help, but again, can't find one for 200.
https://linustechtips.com/topic/1327273-can-u-help-me/#findComment-14652063
Unless you're doing heavy over clocking just swapping motherboards won't make a noticable difference for performance. That motherboard will support a 5600x($230 MSRP)
However, for gaming the GPU would be the upgrade to do, but that's not going to happen for around $200 right now.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1327273-can-u-help-me/#findComment-14652071
1 hour ago, danielhoebenreich said:
GPU can be more than 200$.
The gpu i have is an msi GTX 1660 Super for around 600-700 $
But if there is an cpu for around 200$
You may see a performance jump going to 3600MHz on your RAM. It would be less than 200 and setting up XMP is pretty easy if you don't have it already.
https://linustechtips.com/topic/1327273-can-u-help-me/#findComment-14652286
would it be worth to upgrade from the asus rog strix B450-f gaming to the asus rog strix B450-f gaming II
https://linustechtips.com/topic/1327273-can-u-help-me/#findComment-14654137
