[HELP] Attach an external Noctua fan to a 10Gbe switch
Solved by kriegalex,
Long story short, if anyone ends up here, I advise you do the following :
- You want a totally silent setup, then add a media converter for 10G instead of a transceiver to the setup described (CRS309 + CSS610). This is a total of 10x "SFP+" + 8x 1000BASE-T of which 1 SFP+ is a virtual combo port SFP+/10GBASE-T from the media converter. Warning, the media converter costs at least 2x of the transceiver...
- You want native NBASE-T (2.5G/5G) ports for your next shiny PC/server, or you can handle a bit of noise/high pitch ? You don't need more than 8 ports total ? Then get a MS510 or a XS708 from Netgear (XS708 is fully 10G).
- If you want the above, but you want a mix of total silent and native 2.5G, maybe MikroTik will release the 2.5G version of the CSS610, someday, so you need to be patient... You would keep the media converter and the CRS309. In the meantime, the MS510 seems like the closest thing.
- If you want to go the transceiver route, do it with actively cooled switches/routers and don't bother adding extra fans...
- Your ISP provides 10G internet but without some weird auth mechanisms like in XGS-PON ? You can plug your SFP+ directly into a managed device and just select the appropriate VLAN ? Then you don't have to worry about transceivers or media converters, simply get the CRS309...
