I have an iPhone from work, I think X, or 11.
I can't remember as I have so many devices from work.
The issue is that I put it to charge.
It charge.
So I leave it charging.
But after a while, it as if the charging stops, eventhough it's still connected to the wall socket and doesn't have any switch to turn it off.
The phone then ends up being empty. It only charge again once I plug out and in again.
Is that a feature of iPhone to save battery health?
I might also use the wrong iPhone chrage? It's an official Apple iPhone charger, just not sure it belongs to this specific phone.
https://linustechtips.com/topic/1325791-weird-charging-issue-with-iphone/
Sounds like a faulty charging port/board. Try a diff charger/factory reset if you can. 🙂
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
It charge.
have you tried a differed charger/wall plug
KanyeWestLover911
Reminder
I'm just speaking from experience so what I say may not work 100%
I Use Arch BTW
my PCs
these are my Pcs
https://pcpartpicker.com/user/mtj08/saved/
Usually a bad connector, try clean it / rubbing with alcohol.
Lightning cables are very easy to break.
Very True
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
