I have a windows 10 pro vm hosted on my TrueNAS server in my house.
I am using virtual audio cables to reroute the sound played on this VM through the mic output, so I can output it through discord.
The set up I have at the moment works for the inbuild VNC connection and with anydesk, however thsi instantly breaks the second I RDP to the VM and wont reset unless I restart the VM.
I just to know if it is possible to do this with RDP (mainly want to use RDP for the screen size as I cant change it with anydesk or VNC)?
Any help is lovely
https://linustechtips.com/topic/1325208-rdp-audio-issues/
When you open RDP to connect expand the little down arrow, local resources, audio settings, set to play on remote PC. Might help.
F@H
GPD Win 2
https://linustechtips.com/topic/1325208-rdp-audio-issues/#findComment-14637156
Sadly, that has already been tried to no avail.
At the moment I am looking into the GPO to see if there is anything there that might be blocking it.
https://linustechtips.com/topic/1325208-rdp-audio-issues/#findComment-14637465
RDP is not designed for audio and video, unless remotefx is available which can handle the offloading.
what is your exact goal with this setup?
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/1325208-rdp-audio-issues/#findComment-14645786
