cheapest wireless headpods?
12345678
the sound quality doesn't matter, but it shouldn't also be like noise
the look of it matters, it should be something minimalistic, maybe of some Known brand like sony
I just need to gift them to someone who blast it's damm music all over the house, so I'm not forced to listen to that crap
If the sound is not good, probably he won't use it often. Which defeat your purpose.
KZ S2 would be where I turn.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
If you're looking for something somewhat usable and cheap, just go on Amazon.com and look for cheap headphones with relatively good reviews. I'm sure there is some cheap off-brand ones that would work.
