Motherboard PCIe 'thermal guard' for SSDs - OK to use?
Go to solution Solved by Levent,
thermal guard is a marketing naming of an heatsink. You are more than fine with using whatever your motherboard comes with. Same heatsink also exists on my B450 Aorus M, which never caused me any regret when it came to temperatures.
I'm looking to buy an M.2 drive for my system, and noticed that my motherboard (B550 Aorus Elite V2 [rev. 1.2]) has something that Gigabyte calls a 'thermal guard' installed on its PCie 4 slot.
Given that Gen 4 drives seem to run somewhat hot (even more so depending on the model, from what my research shows), would it be okay to use this thing as a thermal solution, or should I look into a drive with a heatsink instead?
Disregard meme tier marketing names for computer parts.
The integrated nvme heatsink is fine, nvme ssds are usually better off with a heatsink or direct airflow, ideally both, but just about any thermal mass will do. Even finless metal slabs will do pretty good, or at least good enough.
“Thermal guard”
not as bad as “gaming certified”
or “locked and loaded heat pipe design”
can you imagine some kid (because that’s the target audience for these of course) trying to explain to their mom “mom I need the guntherboard, so my gamer friends will think I’m dark and cool”
”look it even has super hearing, mom”
Oh, cool! I assumed it was just their 'gamer marketing' way of saying "yup, there's a heatsink", but still wanted to make sure. Glad to know it'll work fine though. Thanks!
See, that also threw me off at first. I'm used to heatsinks having fins and whatnot, so seeing a chunk of metal on there kinda made me go "huh".
My favorite part is that, from that image, I can't even tell who made that thing.
I guess it is top secret, as it says on the corner...
