hello everyone,
soon (after my exems) i wanne build my first pc. (only owned laptops up untill now)
most poeple think i'n crazy when i say what i wanne put in it but i think it is a pritty soled component list:
nzxt phanton 530 black or white                     € 110
msi atx Z87-g45                                             € 128
intel i7- 4770K                                                € 285
16 gb corsair vengeance (2x8)                      € 148
geforce gtx 780 ti  msi                                    € 604
corsair hydro h100i                                        € 96
crosair cx series modular cx600m                   € 65
crusial m500 120gb + wd 2 tb                         € 147
ASUS PB238Q        LED                                € 204
Logitech G510s Gaming Keyboard                € 98
Logitech G500s Gaming Mouse                     € 63
3x crosair AF120 Quiet Edition, 120mm         € 44    ( € 14 for 1)  for extra quiet airflow
my max buget is €2000
this list of components cost around €1992
prices come from this site (it is dutch so you might not understand every bit) http://azerty.nl/
what do you all think? i don't like half work. That i why i add a 780 ti in there and no regualar 780.
i'n gonne use my pc mainly for gaming, video editing and some hard 3d modeling and rendering
any tips or changes that i sould make?
(oh linus if you see this, could you please add a spellchecker to the forum. saves a lot of time for some poeple like me)
https://linustechtips.com/topic/132421-making-my-first-pc-tips/
before you all ask. yess i'm from holland and no i dit not put those links there. that whent autometic when i copyed the name
seems pretty solid, but what are you using it for? just gaming? 780Ti and 4770K are pretty overkill for 1080P single monitor, also if you downgrade to 4670K and just have a regular 780, you could put the extra cash into an IPS panel monitor. which is so much better than the display you have listed.
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762629
Looks pretty beefy for your specified usage to me. What's your budget?
Also, I use an in-browser spell check or you can type in your comments on a word processing program (like word of OpenOffice) then spell check it there. It's a little cumbersome but hey, better than nothing.
Main Rig: Illya V2, the Tiny Titan: ||i7 8700k 5GHz @ 1.385v (delidded)|| ||NVIDIA RTX 3090 FE|| ||KrakenZ63|| ||ASRock Z390-Phantom-ITX/ac|| ||Corsair SF750||
2nd Rig: Illya V1, the Air Cooled Prodigy: ||i7 4790k 4.4GHz @ 1.3v|| |NVIDIA RTX 2080 FE|| ||Be Quiet! Dark Rock 2|| ||ASRock Z87-E|| ||SeaSonic G-Series 550w (Carbon Fiber Mod)||
Captain isHypnophobic of the LTT Conglomerate.
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762636
i want the 780ti because it can render my work in 3ds max faster than the 780 and than i can later (in about 3 years) add an 2e 780ti too keep the preformance up to date with the new game's i buy this computer with eye on the futere
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762652
By the time that comes around it might be better to just buy the next top of the line card instead of SLI'ing them.
BTW your a scumbag:
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762669
I think there is a spell checker already? But looks pretty good.
thanks. i do my best :) i have dyslexia and englisch is not my own language so it is pritty hard.
but i always keep trying and one day i hope i won't make a single mistake anymore
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762673
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor (€191.90 @ Caseking)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (€33.40 @ Amazon Deutschland)
Motherboard: MSI Z87-G55 ATX LGA1150 Motherboard (€121.95 @ Amazon Deutschland)
Memory: Avexir Core Series 8GB (2 x 4GB) DDR3-1600 Memory (€59.90 @ Caseking)
Storage: A-Data Premier Pro SP900 128GB 2.5" Solid State Disk (€73.68 @ Amazon Deutschland)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (€51.99 @ Amazon Deutschland)
Video Card: Asus Radeon R9 290 4GB Video Card (2-Way CrossFire) (€425.81 @ Amazon Deutschland)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case (€91.39 @ Amazon Deutschland)
Power Supply: SeaSonic M12II 850W 80+ Bronze Certified Semi-Modular ATX Power Supply (€110.91 @ Hardwareversand)
Keyboard: Cherry G83-6105 Keyboard Wired Standard Keyboard (€25.03 @ Amazon Deutschland)
Mouse: Mad Catz R.A.T. 7 Wired Laser Mouse (€67.90 @ Caseking)
Other: Korean 1440P (€350.00)
Total: €2029.67
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-03-27 18:14 CET+0100)
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762690
Total: €2029.67
i'm really no amd fan. i use a laptop with a amd grapics card right now and i'n no fan of the whay the drivers work and how it handels some game's.
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762707
The drivers they use on the laptop is different from the dedicated cards. And AMD cards handle games just fine, but hey if you don't want to use em no ones gonna force ya.
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762723
The original build you created is near perfect.  I would only make minor changes.
1st, get the least expensive 1600mhz, 9-9-9-24 kit of 16GB RAM that you can find.  There is no difference between brands, RAM is RAM, try and save a little bit of money on this component.
2nd I would get a more trusted brand of PSU.  Corsair, and Antec are some very good and trusted brands.  In particular I think you will find the Corsair CX600M to be to your liking.  It is very inexpensive, performs well, and is semi-modular.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762727
the main reason i chose for be quied is because i believe it is more quied. but i do not know how loud the crosair cx600m is. so if you could tell me i would be really happy :D
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762787
The CX600M that I have in my case is unnoticeable.
I have an i5-4670k OC'd to 4.7Ghz
CM Hyper 212 EVO
Asus Z87-A
8GB of Patriot Viper Xtreme RAM
120GB SSD
2TB HDD
CX600M
5x Cougar Vortex PWM fans
My CX600M powers everything with ease.  Really good value, just the right mix of performance, functionality, and cost.
Here is a Power Supply Review Database
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762842
CM Hyper 212 EVO
Asus Z87-A
120GB SSD
2TB HDD
CX600M
thanks that saves me € 31,-- :D
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762870
Here's a build I think might be good fr you. The PSU has enough wattage for you to add a second graphics card in the future. I personally think IPS is really worth it, so I put a great Asus monitor in there. The H100i will keep your CPU cool if you overclock it, and there is plenty of RAM for you, and extra slots if you need to add another set. I tried to colour coordinate everything for you too - it's all red!
CPU Cooler:  Corsair H100i 77.0 CFM Liquid CPU Cooler  (€97.98 @ Hardwareversand)
Motherboard:  MSI Z87-G45 Gaming ATX LGA1150 Motherboard  (€119.99 @ Pixmania DE)
Memory:  Corsair Vengeance 8GB (4 x 2GB) DDR3-1600 Memory  (€84.12 @ Amazon Deutschland)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Disk  (€70.90 @ Amazon Deutschland)
Storage:  Toshiba  2TB 3.5" 7200RPM Internal Hard Drive  (€72.90 @ Caseking)
Video Card:  Gigabyte GeForce GTX 780 3GB Video Card  (€456.65 @ Amazon Deutschland)
Power Supply:  EVGA SuperNOVA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (€102.78 @ Amazon Deutschland)
Monitor:  Asus PB238Q 23.0" Monitor  (€208.97 @ Amazon Deutschland)
Case Fan:  Corsair CO-9050016-RLED 52.2 CFM 120mm  Fan  (€19.90 @ Caseking)
Other: Windows 8.1 64 bit OEM version (€80.00)
Other: Peripherals (€130.00)
Total: €1739.05
(Generated by PCPartPicker 2014-03-27 19:19 CET+0100)
| My first build: http://linustechtips.com/main/topic/117400-my-very-first-build/ | Build for my friend's 18th: http://linustechtips.com/main/topic/168660-pc-for-my-friends-18th-with-pictures-complete/ |
ATH-M50X Review: http://linustechtips.com/main/topic/165934-review-audio-technica-ath-m50-x/ | Nintendo 3DS XL Review: http://linustechtips.com/main/topic/179711-nintendo-3ds-xl-review/ | Game Capture Guide: http://linustechtips.com/main/topic/186547-ultimate-guide-to-recording-your-gameplay/
Case: Corsair 200R CPU: i5 4670K @ 3.4GHz RAM: Corsair 8GB 1600MHz C9 Mobo: GIGABYTE Z87-HD3 GPU: MSI R9 290 Cooler: Hyper 212 EVO PSU: EVGA 750W Storage: 120GB SSD, 1TB HDD Display: Dell U2212HM OS: Windows 8
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1762948
Get a larger SSD. Sacrifice on something, get 8GB of RAM for now, whatever, but don't get stuck on 120GB, it's not enough nowadays. I have one, with both partitions running in red more often than not. Hell, titanfall alone eats a 3rd of that, and you still need good 60GB for your C: drive.
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1764969
hello everyone,
If you are really going to use the PC for a lot of video rendering/editing and 3D modeling go with a 4770k.
If you're not, then just lower to a 4670K.. it's the same thing... Unless you're really stressing the CPU you won't see that big of a difference.
If you plan to Overlclock it then I'd say get a Hyper 212 evo or spend a little more for a H100i with 2 Noctua fans! Silent and cool.
Sacrifice the 16Gb's for 8gb's right now.. Later on you can upgrade to 16 or 32, but you'll be fine with 8gb's, doing so, you can get a 250gb SSD!
Also, 750 watts shall give you head room to maybe get a SLi set up of 780Ti's, if you plan on doing that! And Corsair RM's are really good PSU's.
Also, I trust EVGA or Asus for GPU's. Msi is good, but EVGA jsut has a really solid costumer service and products. Asus's can overclock extremely well.
(I put EVGA just because haha.. but feel free to switch to Asus 780ti direct CU II.)
Here's a PC that I recommend for you. (Heck! I'd want it for myself):
http://de.pcpartpicker.com/p/3hHNx
Current Build:
CPU: Core i5-9600K MOBO: Asus strix z390-i RAM: Corsair Vengeance 16GB - 3200mhz GPU: Asus Geforce GTX 970 Strix Storage: Samsung SSD 500GB & Samsung 1TB SSD Case: Louqe Ghost S1 Cooler: Noctua L12 - 92mm fan only PSU: Corsair SF600 Keybaord: Ducky Shine 3 Cherry MX Red
https://linustechtips.com/topic/132421-making-my-first-pc-tips/#findComment-1765055
