Need some tuning help! (B450)
What is your ambient temp? 20c is 70f. I dont agree you are achieving those temps at all unless you are in a room that is 30f on its own. (I have the same cooler, CM Lite 120 on a 1700....its just fine but aint running at 20c brother)
Are you sure your RAM is actually running at the stated speeds? Or is that just the ram you bought and put in? If so check to ensure its running that speed at boot by checking CPU-Z, memory tab. My bet is its actually running at 2133mhz - if you can get it to 3200mhz or more than gaming wise thats a HUGE upgrade (but see below)
As an overclocker of a few 1700's there are some gains to be had - but unlikely any you would note unless you share with us your use case.
Like for rendering...getting your 1700 to 4.2ghz competes with the R5 3600X handily.
But with your GPU - there just isnt a way that your CPU is "holding it back" so if you are a gamer - your GPU is the issue here and would need replaced
What is your use case?
