4 minutes ago, strix123 said:
Can Arctic Liquid Freezer II - 420 fit into Fractal Design Meshify C Blackout Tempered Glass case?
This AIO is a 420mm cooler (3x 140mm), which the case does not have room for:
Quote
Front radiator: 120/240/360 mm, 140/280 mm
Top radiator: 120/240 mm (max component height on motherboard 40 mm)
https://www.fractal-design.com/products/cases/meshify/meshify-c/black/
You either need to go down a step in terms of cooler (like getting a 360mm/280m cooler) or get a different case if you're set on the cooler.
3x 140mm AIO compatible cases are somewhat hard to come by. The Fractal Design 7 is one of the few I could mention off the top of my head which supports it:
Quote
Top radiator: Up to 360/420 mm
https://www.fractal-design.com/products/cases/define/define-7/black/
Although with top mounted AIOs you do have to look out there is enough clearance for your memory and larger motherboard heatsinks
https://linustechtips.com/topic/1321672-case-aio-compability/#findComment-14612061
